Does anyone know if the clock dampers on the XS 250,360,400 etc will fit an 400C. If so i'm after some.
yep, the SOHC are all interchangeable with very little design change.
the custom variants have longer forks and 16" wheel with a longer swing arm.
Have you got the dampers yet?
No they arnt available for RD400 but seam to about for the XS range.
Didnt post RD in the first post did I my apologies Drewpy.
OK, may still work for you. If you can measure your clocks I can measure mine (that's CLOCKS, not Cocks) :razz:
I think the clock are the same diameter just the rev range on the tacho maybe different.
my xs400 starts to red line at 9.25k if that helps
Only if it effects the rubber dampers.
