Posted March 14, 201312 yr Hey folks, having probs. When i turn off the ignition the clocks stay on even with kill switch off. I guess it's a short somewhere. A code 51 is displayed on the clock, bike won't start, but pull in front brake & the needle swings then will start. Any ideas? Cheers. Sharpy.
March 17, 201312 yr Diagnostic code 51 relates to the Radiator Fan motor relay. Not sure if that's the same as a fault code but going into diagnostic mode will test it for you. You can grab the service manual here: http://vstar1300.pbworks.com/w/page/5760692/FrontPage If that doesn't help, try the folks here as what they don't know about the 1300 Yamaha won't know....http://forums.delphiforums.com/n/main.asp?webtag=vstar1300&nav=start&prettyurl=%2Fvstar1300%2Fstart&gid=2012354655
March 26, 201312 yr keep us posted on the outcome sheepy please... would be interested to know the outcome
