kenDAWG Posted March 12, 2013 Share Posted March 12, 2013 Well after messing with my bike and putting it together with a few tweaks to carb a new set of clocks she won't start ill give you breed description. Turn key Powervalve cleaning cycle completed Choke on Kick It fires once, fumes out of exhaust Stops This happens every time I kick tried bumping etc Am I right in thinking there is a break in the circuit from the stator? Maybe pickup? Ideas anyone? Just fitted a new battery aswell Cheers Ken Link to comment Share on other sites More sharing options...
Moderator Airhead Posted March 12, 2013 Moderator Share Posted March 12, 2013 try undoing the carb drain screw and turning on the fuel Ken...I'm thinking theres no fuel in the bowl You can check if it's an elec issue easy enough...Just see if the plug is sparking Link to comment Share on other sites More sharing options...
kenDAWG Posted March 12, 2013 Author Share Posted March 12, 2013 It's getting initial spark but no follow on to keep it going! Floatbowl fills the furling is there just the electric side Ken Link to comment Share on other sites More sharing options...
Moderator Airhead Posted March 12, 2013 Moderator Share Posted March 12, 2013 have you took out the plug and reconnected to the HT lead, rested the plug on the engine and checked the spark? Link to comment Share on other sites More sharing options...
kenDAWG Posted March 12, 2013 Author Share Posted March 12, 2013 Not yet pal I'm gonna have to do that tomorrow! I'm just going by what the engine is doing I was looking at ideas in what could be the cause. Was working before I decided to fine tune the carb which needed most of the plastics and the tank off so I think somewhere I've either nipped a wire or shorted something out! Kinda need it for work, I have to get lifts until I can sort it Cheers Ken Link to comment Share on other sites More sharing options...
blackhat250 Posted March 12, 2013 Share Posted March 12, 2013 Is the choke connected ken" Link to comment Share on other sites More sharing options...
kenDAWG Posted March 13, 2013 Author Share Posted March 13, 2013 Yeh pal choke is connected, its a strange one I know! I've done something stupid haven't I because I'm a dumbass Ken Link to comment Share on other sites More sharing options...
nayruf Posted March 13, 2013 Share Posted March 13, 2013 Hi Maybe a real dumb suggestion, does this bike have a Ballast resistor in the ignition circuit? Link to comment Share on other sites More sharing options...
kenDAWG Posted March 13, 2013 Author Share Posted March 13, 2013 To be honest I have no idea! It's a 2003 dtr... Ken Link to comment Share on other sites More sharing options...
