dt 125 water pump
ive had water in my bike because it wasn't cold for weeks but because of this weather it froze everywere in my bike theres no cracking on my engine but i suspect my water pump is destroyed ive put coolant in it now and ever since that day my bike temp will shoot up to red within minutes =/
Cracked head internaly,check you spark plug bet it clean like new.Also check the thermostat.
ive removed the thermostat weeks ago because it was rusted and broken and great looks like im goin to need a new top end =(
Try a new thermostat first, might just be the problem?
it was working fine without a thermostat in i just took a little longer to warm up now it just shoots to red as soon as i go down 1 road
Did you pull the plug yet?
going to do it tomorrow ive got work soon on night shifts :( got a week off starting tomorrow though ganna strip her down then
Try filling it up not running(coolant) then fire it up if it pisses it all out the over flow tube then internal crack.
i filled it up with coolant yesterday then started it all the coolants still in there non came out anywere
Still in there as in the cooling system or the engine in general.
What is the gearbox oil like.
well when i flushed the engine i poured water through and had the bolt out so it went from the rad out the bottom of the pump fine so i put the bolt in and filled it with coolant and i will let you know about the oil tomorrow when i strip the bike :)
Then your lucky if the head was cracked it would be pressurizing the coolant system and blowing it out.
sweet, none has came out since i put it in yesterday still at the top of the rad :) i know something bad is wrong though the bike just vibrates loads
It will only come out with the bike running ,when the head gets hot enough for the crack to open,the plug will tell all if it's steam cleaned then cracked head.
plugs as dirty as it always is so no cracks :) yam dealers want 60 quid for it, i cant find any other ones online any ideas?
Any chance the Temperature Sensor could've got damaged by the freezing water??
Could be sending a dodgy signal??
Danny......
thats what i was thinking but the engine vibrates quite alot but when i feel the side on the barrel when its indicating its red not its still not hot to touch butthe outside casing is cracked on the water pump not a big one but its noticeable
ive taken the casing off and there's no cracking on the inside and the water pump spins when the bikes started so i have no idea what it could be
Sounds like the sender unit.
The vibration is an unknown. The ice could have done all sorts of wierdness. You could have damaged the sleve or parts in ths sidecase.
You can test the sender by taking it out and putting it in boiling water. That should show above normall temp but not in the red. She should be running 95 deg or therabouts.
so if its the sender unit my bikes not going to blow up? and its alright to ride?
