Jobigee1982 Posted March 10, 2013 Share Posted March 10, 2013 Hi anyone who can help looking for advice about running bike as it was running fantastic until the other day when going over the 6000 rpm mark it did not take off as normal and seems to hold back any one have any ideas ?? Link to comment Share on other sites More sharing options...
dt502001 Posted March 10, 2013 Share Posted March 10, 2013 Your going to have to be a bit more specific,or take your foot off the brake Link to comment Share on other sites More sharing options...
Moderator drewpy Posted March 10, 2013 Moderator Share Posted March 10, 2013 fuel or ignition Link to comment Share on other sites More sharing options...
Jobigee1982 Posted March 11, 2013 Author Share Posted March 11, 2013 Lol not sure if it has power valves or somethimg like that that used to kick in and now it does not have a manuel but don't know what I'm looking to fix Link to comment Share on other sites More sharing options...
neversaydie Posted March 11, 2013 Share Posted March 11, 2013 Lol not sure if it has power valves or somethimg like that that used to kick in and now it does not have a manuel but don't know what I'm looking to fix I think its basically the same motor as on the FJ, FZ, and YX models. Thing to do is start looking at the simplest and cheapest possible faults - plugs/air filter/ filter in the fuel tank, is it a vac operated fuel tap - if so check the carb rubbers for leaks or poor fit. Cant remeber if theres a fuel filter in the fuel tap - check that too. Fuel tank air vent clear/? Low compression. Valve clearnaces. Ethanol in the fuel? Clutch slipping Easy things first before you pull the carbs to bits Good luck Link to comment Share on other sites More sharing options...
Jobigee1982 Posted March 12, 2013 Author Share Posted March 12, 2013 Thanks for your help will give it a go Link to comment Share on other sites More sharing options...
wild foamy Posted March 12, 2013 Share Posted March 12, 2013 Check the condition and colour of your spark plugs, my XJ600 used to be very picky about its fueling, a good mixture should be a dark chocolatey brown, also check the rubber gators that go between the carbs and engine head (chances are these are perished and they are more rare than rocking horse sh*t with hens teeth in it) also, make sure your exhaust is in good condition, it may sound stupid but it makes a hell of a difference to these little bikes when they have the right backpressure Link to comment Share on other sites More sharing options...
Matthew Duncan Posted March 12, 2013 Share Posted March 12, 2013 sounds to me like it might a problem with your powerband, i would reccoment replacing it with this one - http://kalecoauto.com/index.php?main_page=product_info&products_id=36 Regards, Link to comment Share on other sites More sharing options...
neversaydie Posted March 13, 2013 Share Posted March 13, 2013 sounds to me like it might a problem with your powerband, i would reccoment replacing it with this one - http://kalecoauto.com/index.php?main_page=product_info&products_id=36 Regards, Link to comment Share on other sites More sharing options...
wild foamy Posted March 13, 2013 Share Posted March 13, 2013 sounds to me like it might a problem with your powerband, i would reccoment replacing it with this one - http://kalecoauto.com/index.php?main_page=product_info&products_id=36 Regards, That site never gets old! XD, Link to comment Share on other sites More sharing options...
Matthew Duncan Posted March 15, 2013 Share Posted March 15, 2013 seen an oppertunity, had to take it! Link to comment Share on other sites More sharing options...
