main bearing removal...
Cynic
This post is 4207 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
oh dear, take a deeep breath and start again.
Things like this happen to me and I've decided I just get on with it and not lament
True drewps. I had my tantrum. Swore at the sun, moon and thestars then looked at ways to fix it.
So after 2hrs with a swiss file and patience i have rescued the thread. Acid test will be when she runs but i see no reason for it not to work. Have to be careful starting the nut to be sure its square otherwise it looks ok.
After today i will see how it goes. Its taken too long already dont want anymore disasters.
If only the last few threads are nfg what i have done is to file them flat/tapered so starting the nut only contacts the lowest part of the undammaged thread,run it in and out a few times with a different nut or if you have a die better.
Hope it goes together better next time.
