wtf have I done to deserve this shit?
Thanks guys : ), Yeah I have to be over the worst now : ) can't see anything major going wrong now. I have taken extra care of the engine using top oil and changing regularly. All it needs now is the fork seal and the electrics sorted.
Congrats on getting it all sorted Grouch. Any idea what bearing type/model/number they replaced your bike with? I experienced a similar situation today on the motorway so looks like a bearing replace is in order. Going to attempt doing this myself but the Haynes manual says I need some kind of "Internal Expanding Puller" tool. I'm hoping it's a load of crap and I'll be able to pull out the bearings with a flat head screwdriver.
They just said they used sks bearings which are a good brand. You need to make sure you do it properly otherwise your putting yourself in danger.
Don't pull the bearing out (1st you will never pry it out 2nd you will make amess of the hub) drive it out from the inside oppsit end with a long punch/bar..through the hole that the axel fit's through.hit it at 12o clock then 6 -3 -9 and work aruond it till it pops out even/straight with the hub
Ahh that sounds like a better approach to this dt502001, thanks. Going to do this now.
I would have shit myself.....least your okay
Glad they fixed the bike and done that freebee for you mate, so now when you turn your head light on dose the brake light go on full beam? :D
Yes this was happening and they said it was a bad earth.
