xj600 motor problems, i need help
johnmaxwell
This post is 4263 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
As you PM'd me
Your bike is only running on 2 cylinders,,,,,,,, the 2 that are getting hot.
You probably need to clean the carbs.
What else is it doing When ya try and start it ?
What have you done ?
Does it start up easy as it is now ?
How long has it been lying before you got it ?
More details required
Link to comment
Share on other sites
  • 4 weeks later...
sounds very much like a faulty coil or possibly CDI unit. mine had a faulty coil. There are two coils, one runs cylinders 1 and 4, the other runs 2 and 3. that would be the first check I would make.........:)
Link to comment
  • Recently Browsing
