speedo not working
good evening everyone on the way to work today i noticed my speedometer had stopped working
any advice on diagnosing the problem and how to fix it would be most appreciated
thank you
Liam Wallace.
ah is that the cable that is attached to the front wheel?
how will i know if it has broken sorry to be a bother.
Is the speedo in question from your DT? If so look at the speedo dial and locate the cable(s) coming from it. Follow the cables to where they end and closely look at them to see if there are any breaks in the cable. Also closely check where both ends connect.
it is yes
ok i will have a good look tomorrow once i finish work thank you for the advice.
Thank you for the help folks it was indeed the cable i will replace it asap.
Liam Wallace
Generally these things break at one end or the other, so unscrew each one and pull on the inner spine. If it comes out then it's broken, simple as!
Next test is to unscrew both ends and turn one while observing the other. If the other end does not turn then it's also broken, simple as!
