FZR600R and others speedometer cable replacement tip
To replace the cable just remove the screen and remove the two instrument cluster nuts with an open ended or flat 10mm ring spanner. Now lift up the instruments and remove old cable and fit new one.
Hope this helps someone, saves taking the front fairing off.
