crossplane hard starts
This post is 4316 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I have been reading a lot lately about hard starts and rattling/ticking noises in R1s of different years. I purchased mine used last year with intentions of making a track bike out of it. After a week or so I too noticed the famous "ticking" sounds they love to produce. I took it to the wizard here in Tennessee and found that the cct was in fact bunk and replaced it.This did help some with the hard starts, I'm guessing that it caused improper timing issues. We checked the fuel maps and found them to be right on for stock settings. Still after a few days of sitting it is hard to start. Any other ideas???
Link to comment
Share on other sites
Welcome crossplane [ crank] :eusa_think: , Its a bit to modern for me them R1"s... post up in workshop area.. :welcome:
Link to comment
Hi crossplane,check the injectors for leaking.
Link to comment
Thanks for the welcome blackhat and I'll copy and repost. dt I'm assuming your talking about fuel backlashing causing pressure drops right? O rings should be fine otherwise i would have compression leakage
Link to comment
I was thinking along the line of injector needle not seating due to deposits,leaking fuel,have you tried injector cleaner?
Link to comment
Hi & Welcome Crossplane. You say Hard Start is that turning over OK but not firing or slow turning?
All the end camchain large engined Yams rattle FZS1000, all R1s and my FJR and a few had valve guide issues so the question is how is the compression and are you burning oil at start up?
PS. The rattle is it around No 1 valve?
Link to comment
The rattle ended up being the cam chain tensioner. While i had the access to everything i checked valve lash and some were slightly off. The hard syarts are still under investigation due to my ignorant american ass killing a cell in the battery. I purchased another battery yesterday (along with oil and filter that costs over $130 dollars) but the battery ended up being wrong as the posts were on incorrect sides. I have been told to crack the throttle slightly when starting to reduce the amount of drag on starter so hopefully that will help.
Link to comment
  • Recently Browsing
