How the hell do i remove this?
shambles1980
This post is 4304 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Shambles, if you run the bike without the baffle in you will burn out the piston if you don't retime it, plus you need the back pressure to help the piston to actually go up and down, had a honda once upon a time and it sounded great for a while until the tops of the pistons fell off :shakeno: stick with hot water and detergent and if you want to keep it hot use a blow lamp on the silencer to keep it on the boil. :jossun:
Link to comment
Share on other sites
Some one has already pulled the cross bar out!
Caustic soda was never that good. a good fire might ruin the chrome but sure did loosen the carbon in the exhaust
We used to weld in a nut and use a slide hammer if the baffles wouldn't shift
Link to comment
