flywheel casing
my chains snapped in half, it went on a mad one and ruined my casing, 3 bolts have fell out and gotten lost and the others are all bent does anybody know any were i can get some new ones for cheap? i cant find them anywhere and a new/used casing would be good too.
Bad news heywood" did it break anthin else, a spare engine from breakers is a plus, :yeah:
just the flywheel cover :( and bolts it wouldn't be as bad if i could just find some, recon i could get away with putting any old bolts in? as long as i have the main gasket on it should be alright? defo getting a new chain tho this one looks like its had its life.
yer lucky " i had a CR250 and the chain wrecked the clutch actuator housing .. ahole right thru, oil leaked , that was a engine casing split to fix, :eusa_doh:
owch i would of been gutted lol hop fully have her back on road within a week depending on delivery
i had not long got the bike :P the chain didn't look the best but when i took the engine out i coated it in wd40, wemoto have a d.i.d heavy duty for 35 quid im going to get that is the front sprocket i need to get with less teeth for better acceleration?
Yeh " but top speed will drop to about "60,m :eusa_think: ph
ahhh that ideas out the window then thanks haha
