January 19, 201313 yr the other day before the snow. i started puting together the bits for the new barrel for my rxs 100.. any way i have a reed block with fiber racing reeds on it and when i went to install it i noticed it did not like to fit in the inlet.. the reed stops had been bent outwards.. I assume this was so the petals could open farther, i was wondering if there is a set distance they should be.. i dont mind bending them back and measuring the distances to a rough accuracy. i really doubt that having the stops bent out that far helps the performance any, If no one knows thats ok and i can just compare to my other reed block.. BUT given that was on The bike with a bad barrel. i would not be suprised if they have been bent in or out too. .
