Posted January 10, 201312 yr Has anybody fitted USD's to a dt? I have seen it done and need any info ie which ones will fit and how easy is it if I wanted to put ones of a YZ... Ano it's not an good post but would be grateful for any info Cheers Chris
January 11, 201312 yr in theory you could put YZ forks (including brakes and wheels) on it providing they have the same yoke diameter, failing that you could swap out the whole 3-tree (yokes) fro, the YZ provided that the internal spindle is of the same diameter.
January 12, 201312 yr Would be a pain the arse if you needed to have the stem pressed in. It may also mess up the handling of the bike as they will most likely be a different length stanchion. If its just for looks i personally wouldnt bother.
January 13, 201312 yr Author Ok cheers guys, it's something I've wanted to do but yea mainly for looks. Ill keep looking into it and see what happens.
