January 9, 201313 yr im waiting on the piston kit now but i have taken everything off and was just wondering i know were the twostroke pipe goes but theres 3 pipes coming off my carb (different to the overflow pipes and i don't know what ones for what im new to these engines as ive only messed with 50cc peds before, any pics and info would be much appreciated.
January 9, 201313 yr 2 will be water pipes, mine has them on my cylinder head - one comes from the thermostat an elbow on the side and the other comes from its own feed on the head so im guessing one is flow and one is return....
January 9, 201313 yr Do they have automatic choke " ,, whats the heat neaded for ,,carb icing ,, like the Sptfire,,,
January 9, 201313 yr Author the engines around a 2003 there all the same i believe from 1988-2005 and no its a manual choke and its a dtr
January 9, 201313 yr Yep Blackie,,,,, no carb icing on these ahaywood, One pipe is fuel and the others are water to the carb. When you putting her back togeather youll know wher they go as the lengths of them are different.
January 9, 201313 yr Author ahhhh okay im just waiting on the piston once thats fitted ill be putting the beauty back together
