August 20, 200520 yr Hi all, Right i'm thinking off some engine mods over winter now i'm running a full system no exup on it with a k&n and set up on dyno running about 115bhp.need some tips on some cheap way of getting more power???Any thoughts?? Heard of putting thunderace top end on or what about fzr 1000 top end???Any one tried this or done some think similar. Also the famous oil burning now using about 1litre every 1000miles ish depends on how hard the ride was out. Whats the best part to renew as don't start doing rings and its usually the valve guides for example.. thanks for any help dave....
December 31, 200519 yr Hi all, Right i'm thinking off some engine mods over winter now i'm running a full system no exup on it with a k&n and set up on dyno running about 115bhp.need some tips on some cheap way of getting more power???Any thoughts?? Heard of putting thunderace top end on or what about fzr 1000 top end???Any one tried this or done some think similar. Also the famous oil burning now using about 1litre every 1000miles ish depends on how hard the ride was out. Whats the best part to renew as don't start doing rings and its usually the valve guides for example.. thanks for any help dave.... mines doing just over 100 and its standard !! seems a lot of work just to get 10 to 15 more let alone more over that !!
December 31, 200519 yr mines doing just over 100 and its standard !! seems a lot of work just to get 10 to 15 more let alone more over that !! got the factory kit manuel showes how to and what to do to make it like a factory ride can e mail it if u want a copy
December 31, 200519 yr got the factory kit manuel showes how to and what to do to make it like a factory ride can e mail it if u want a copy I did have the option once of buying a ex boost team works engine and a load of ex works parts
January 3, 200619 yr Author that be great exup freak me email is [email protected] now ex works engine sounds great but not sure if i'd want the unrideable bike for the road. the way its going at mo it just having top rebuild and and maybe back to local dyno shop as they can play with jetting a bit more for more horses.. replacing my valve stem seals due to using to much oil and found that had all ex valves bent and 4 inlets bent and had to re-sim them all last year and think thats whats caused it..
January 6, 200619 yr Moderator See if you can get yourself some flatside carbs from a breakers off the SP, you can feed some more fuel in which will add a bit.
