i have a problem with xt600 1988 cdi
i have xt600 (eng.nr.47N-00155) .The CDI is cut down. Bay one, nippondenso 29K-50. Did i can use this on my bike? How can do that? Please help!!!!
I'm not sure about the CDI, but I'd suggest you check out and then post an intro. That way you'll get more of a response to your question. :)
:welcome:
Also " your not clear , what does cut down mean,, :shrug: ,, needs to have same number of wires as old one,,,
These boxes are prone to failure and they give slightly different timing curves. There are several versions of the CDi unit and a TCi unit which is not compatable in any way with a CDi.
There is a somewhere a website where the author has drawn up a CDi circuit - but it runs very badly. he also lists which cdis he THINKS may work on other bikes. search XT600 cdi and you'll find it. I don't endorse any of the claims made on the site.
