January 2, 201313 yr I will shortly be replacing the crank seals on my DT400E and I thought that whilst the crankcase covers are off I'd get them cleaned up, any dents / scuffs repaired and repainted to original (or as close as) spec. Does anyone know of any company's around the Northwest (UK), preferably Manchester / Stockport way that could do this work to a good standard. And at the same time, do the barrel and cylinder head? Also, what would be the best finish for the crankcase covers? Powder coat, enamel paint, something else?? Same with the barrel and head. Thanks
January 2, 201313 yr Aye DT" since yours is the satin black finish,,, i recomend click on the 2stroke forum, find the posts with a guys ypvs cases and barrels, and follow his step by step prep and finnish, oustanding quallity. http://www.the2strokeforum.proboards.com/index.cgi
January 3, 201313 yr Moderator you can get them Vapour blasted at Joseph Percival vapour blasting and spray them in PJ1 satin black paint. 10% off for members
