New to forum - i need help please!
When I turn the handlebars on my 2008 xt125r the headlight flashes. When the bike is on the light comes on automatically which is normal, but when I turn the bike the light dims. I have taken all the instrument panel off and there is no wiring problems/bare wires etc anyone got any ideas. Also the neutral indication light on the dash (blue light) has also disappeared. Don't know if this is part of the same problem. Thanks in advance for any ideas or help.
Hi Macca, Check the wires where they go around the head stock and back to the battery, you might have a trapped wire in the loom, it's either broken or worn through, also check your earth wires to make sure they are not covered in crud and have a good seating. Hope that helps a bit. :jossun:
