xt125r speedo
hello
i have a xt125r 07-08 model the speedo has changed from enduro to supermotard and i cant change it back i tried following the manual but the speedo is not doin what the manual said any help would b much appriciated
thanks
Hey dude, had the same issue, it seems this happens when you disconnect the battery or fit a new one. Put the key in the ignition, but don't switch it on, wait for it to flash 'endr' then switch ignition on, wait for it to flash from 'ntdr' back to 'endr' and press the blue mode button on left hand bar (if you have one) that should sort it.
