December 6, 201212 yr Hi all, I have a really annoying (and expensive) problem, My bike keeps killing plugs, If i put a new plug in it will start first kick and run perfectly all day with no problems at all but as soon as i go to start it the following day it will start up, idle then as i put revs on it will bork then die (killing plug). The spark plugs are black when i take them out, Could this be caused by the air mix screw on the carb running too rich?? Any help will be much appreciated Thanks
December 6, 201212 yr Moderator Hmm thets a new one, you may be able to revive the plugs on the cooker gas ring and a fine wire brush...as for whats causing it? clean air filter? jet size? you do know how to use the choke... haha?
December 7, 201212 yr Black soot on the plug is carbon, which will short the electrode out. Your problem is more to do with fuel mixture more then the plugs. As mentioned above, cleaning the plug will restore it but you need to get to the real cause of the problem and check the carburation.
December 7, 201212 yr Author Hmm thets a new one, you may be able to revive the plugs on the cooker gas ring and a fine wire brush...as for whats causing it? clean air filter? jet size? you do know how to use the choke... haha? haha yeah i know how to use the choke
December 7, 201212 yr Author Black soot on the plug is carbon, which will short the electrode out. Your problem is more to do with fuel mixture more then the plugs. As mentioned above, cleaning the plug will restore it but you need to get to the real cause of the problem and check the carburation. Yeah as i first thought, i have just noticed that the air screw on the carb is turned right in and the head isn't on it for me to screw back out :'( Is that most likely the cause of my problem?? Either way i'll have a look see at the jets ect Thanks
