December 18, 201212 yr Author Apologies if my post was responsible for causing excessive arousal! You can imagine how I felt when I first laid eyes on it. Clearance is tight but it will be OK. With the fork springs removed and forks compressed there is about 10mm clearance at full lock. Maximum dive at full lock is not a situation I would like to find myself in! Crazy
December 18, 201212 yr Moderator Apologies if my post was responsible for causing excessive arousal! You can imagine how I felt when I first laid eyes on it. Clearance is tight but it will be OK. With the fork springs removed and forks compressed there is about 10mm clearance at full lock. Maximum dive at full lock is not a situation I would like to find myself in! Crazy
December 19, 201212 yr Author Previous post was in answer to comments (above) by wild foamy and don't make sense out of context. Crazy
December 22, 201212 yr ive been saying that for years, and they thought i need to "see a specialist"...
January 6, 201312 yr Author A fairly important component! Stroked 4mm to 58mm; re-balanced to suit the Wössner 73mm pistons; PEEK coated big-end bearing cages and thrust washers: Tungsten alloy counterweights: Crazy
November 9, 201410 yr hi can you please tell us what kind of power values you are using and where to get it from & what is the cost of it thank you.
