November 28, 201213 yr Just got a 1992 Tdm 850, It's missing between 2500 to 3000 rpm.s any idea.s folks to what might be wrong, It's runs better on reserve than it does on main tank too can't seem to work that problem out,
November 28, 201213 yr if it runs better on reserve than on main then you may have fuel tap problems ie dirt or something blocking the tap solution strip the fuel tap and clean this will probably sort the missing problem also check your float levels in the carbs the carbs could be needing cleaned/balanced hope this helps
