November 26, 201213 yr Hello, new member here. I just recently bought a DT400 missing most of it's body work and electrics since it was ran strictly off road. It was advertised as a 75 which would be a 400B. The VIN on the frame is 450-x which according to http://auction.netbikes.com.au/vjmw.php?page=yamaha_id is classified as a "DT250 Japan." The engine VIN is 501-x which says "DT400 Japan." Am I safe saying that it is a 75 when I buy parts? Also would all the cables and wiring and such for a 75 (if that is the correct year) DT400 fit on that frame? Is the bike even worth restoring to a roadworthy/sellable state since the frame and engine VINs dont match?
November 26, 201213 yr I have the Frame as being a 74 DT250 made for the Japanese market as you say, and the engine Is from 75 DT400J model bike. If restoring to go back on the road, it will be classed as a 74 bike as its the frame vin which governs this not the engine.
November 26, 201213 yr Moderator Was this not the same as that fellow who thought he had something special a while back.... Wonder if the japs raided the parts bin for the convicts
November 26, 201213 yr Yeh most parts will fit frame,,,Electrics " the DT250 B has points, and DT400"s [ all] have CDI. So make shure its a 400 loom, Prices ? check ebay, i know DT"s are cheap in the States, unless its low milage clear title, unmolested ,,
November 30, 201213 yr Author Thanks for the info. I'm gonna try to get it up and running. I'll post a pic after I get the seat back from the upholstery place.
December 10, 201213 yr I would say no. the 125/175 are smaller items , i found this out the expencive way,
December 11, 201212 yr Author That's kinda what I figured. From the pictures the locations of the holes look pretty similar but I could tell that the lengths of the fenders were definitely different. I decided not to risk it..
