Howling/Screaming Noise
Halloween has been and gone, so it shouldnt be screaming and howling and more !!!
My money is on = you need to repack the wheel bearings with High Melting Point grease. (black in colour)
Once you do this and ride the bike for a while, you need to check bearings for play again. Once the bearings free-up ya might find that they are fooked !
It could also be coming from trapped air in the rad system. Being the time of year it is (cold) you might as well put in new coolant and re-bleed the system properly.
HTH
Pat
mr sensible? how are you pat ,were you been hiding.
Hey Kev, how you ?
A've been busy
It must be the wheel bearings Pat, gonna change um tomorrow, everything else is checked and replaced if needed.
Ed
Sorted...Front wheel bearings replaced and no more noises. :hyper: After chatting to a yamaha mechanic it seems that on a Fazer, even if you slightly over tighten the wheel bolt when refitting the wheel it can bugger the bearings causing this revolving, screaming noise!
Whilst the wheel was off I also cleaned up the Speedo assembly which wasn't running as freely as it should and had a slight squeak....Could it have been that?
I also fitted some trim to the edge of the double bubble screen....could it have been that? I doubt it.
Main thing it's sorted now
Thanks for your input and suggestions
Ed
