HT leads repair advise requested
Ive a 1982 Yamaha XJ650, 12,000 mile std condition.
Noticed this week the HT leads are arcing at low rpm.
The HT cables on this bike are molded into the coils.
I dont want to replace the coils or splice new HT leads or replace the lead and remold into the coil.
I want to put an insulated tube over the existing HT leads to fix the problem.
Anyone know where I can find this type of insulated tubing?
Any other ideas welcome.
Hi Simon
If you do a google search for 'Heat Shrink Tubing' you might find that this is what you are looking for, It will insulate the leads ok, but I don't know how long they will last or how flexible they will be once finished,
When I use this tubing I use a Hot air paint stripper type gun on a low setting to shrink tubing.
Hope this helps
there are other types of tubing you can use.
have a look at vehicle wiring products to see the range
I would renew the coils if needbe" as sometime in torrential rain, miles from home, their gonna short, any tubing will have capillary action, , whats coils £25. :eusa_think:
