tzr 125 oversized jets ??
hello, i am currently trying to restore a old beat down Yamaha tzr 125, engine is 2rh btw =)
while looking through the receipts of parts replaced i noticed that the jets in the carb have been replaced
1 X 190
1 X 195
1 X 200
i remember seeing somewhere saying that the standard size for the bike is 180 if i am not mistaken, are these too big for the bike ? assuming theses are currently installed. will they cause the engine to stutter? as in previous post i stated that in 3rd gear up the engine wont hit its power band, it just stutters and slows down at high revs.
thanks for any help
mikuni hex heads ( brass )
Its down to mixture , running at the leanest possible without seizure, too big a main, and it will bog the engine, too big a front sprocket would hamper a small CC bike, check your plug colour, [ after a blast,] , light brown is good,
Air filtre" need atention too, nore fuel [ big jet] = more air = more power, :jossun:
You need to check how she is running. Fully unrestricted a 240, even a 250 can be needed.
