Yamaha aerox
Ktmkray455
This post is 4329 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
You need to do an intro in the new members section before
anyone will answer you. It's considered good manners on
here. Just tell us what bikes you have and where your located.
Sounds like a carb -fuel problem, :eusa_think: did you put it all back correctly, and is the piston in right way, ^ to the front, .
I have put the piston in the right way and fuel is getting to the carb and all jets are clear, float is fine, just had new spark plug, air filter and ht cap but still won't rev, it just about starts but only stays running with full throttle but even still with full throttle is revving out to about 2,500 rpm, thanks for the suggestions
