November 11, 201213 yr so i finished my yamaha dt125lc2 project back in march, and all is good, but in may i noticed my bulbs kept blowing after a little detective work i cam up trumps, as it ws the summer months it never really bothered me and the problem slipped to the back of my mind, but now the summer months have come to an ebrupt end, i think now the problem needs to be sorted once and for all ,, i stripped my plastics to view my battery, and noticed the earth had come loose and disconnectedm itself. after amending tht problem, i went for a spin up the road and all was well till i opened her up and again like many times before my bulbs blew, first the normal beam then the highbeam,,im coming to the end off my wits with this bike and will consider selling it if i cnt fix it soon as catchin the bus and being stuck in traffic all the time is not fun,,especially when i use to laugh at people on buses as i blasted pass, even more so when they were stuck in traffic, so people any ideas in advance wiring to me is a no go so lamens terms would be much apprecitaed lol thanks in advance ps ive uploaded a picture but not sure if it will work never done it before
November 11, 201213 yr Author no the image upload didnt work as you can see feel free to advise on how to please
November 11, 201213 yr If the are blowing when you rev up i would be thinking regulator?, check the voltage across the battery with the engine running, also if the regulator is toast the battery is likely to be also so check it hasnt boiled dry
November 11, 201213 yr As foamy says rob" the regulator , is a bolt on- plug in part , no electical skill, consult manual for its position, And come on " britain never got GreaT giving up,,
November 11, 201213 yr Author any ideas on how to upload a picture to this post as i want to show you all my finished project, and im not sure if my regulator is both a rectifier aswell. when i took my battery out earlier it had like a white powder on the side of the battery and on the housing,, thought it was some kind of wear from vibrations ?? thanks for the suggestions everyone ps ive checked to voltage before nd it said 20 volts, my mate said tht was normal as 12 would go where its needed and the rest to the battery
November 11, 201213 yr Ha rob" tell you mate hes a blether, about 13.5- 14.5 , will be max to battery, then the regulator gets rid of excess ,, That white powder is battry acid,,[ boiled off,] or you coke staash" see F.AQuestions for piccy"s
November 11, 201213 yr Author my mate checked tht though from behind the hed lights,, not sure if the check would of tested the voltage before the reg rec or after,,no advice on the pic upload then and thanks ill look at the pics now mate
November 11, 201213 yr Moderator chances are Rob that it's only your battery thats sh4gged, get a new one and then do the tests on the charging voltages
November 11, 201213 yr Author yeah thts my idea for tomorrow mate when the bike shops open,,im just hoping i mnage to get to the bottom of the problem but it beats me id hate to hate to have to sell it its my baby,,
November 11, 201213 yr Moderator yeah thts my idea for tomorrow mate when the bike shops open,,im just hoping i mnage to get to the bottom of the problem but it beats me id hate to hate to have to sell it its my baby,, Thats not gonna happen Rob
November 11, 201213 yr If your battery is the serviceable kind (where you can pop the caps off the top and fill with distilled water) then check that there is water in the battery, no water is a good indicator that the battery has been overcharged, and a faulty regulator is likely to be causing the overcharging. with the bike running put a voltmeter straight onto the battery terminals, it should read 13-14v or there abouts, 20v is waaaay too much, it is likely to be behind one of the side panels or possibly under the seat, im not familiar with your bike so it could be anywhere, like blackhat said its a bolt-on part and easily replaceable
November 11, 201213 yr Moderator dont forget that there may be nothing really wrong with the regulator. It may simply be a bad connection, broken wire, insecure ground etc
November 13, 201213 yr Author i went over the bike yesterday with my uncle whos an electrician not a mechanical one but yeah, he has a very good knowledge off the voltometer compared to me,, all i know he did was put the red prong on live and the black prong to the earth on the frame and said nothings shorting,, so i pedrsume he checked for continuity or something, as i said erlier leccys really not my thing lol,, and ive found the reg rec under my tank next to the ignition coil,,,im not sure these can be tested any ideaas on this particulr question lol..an no my batter is a sealed one [so no plug caps in top],,thanks again everyone i appreciate ur help
November 13, 201213 yr the rectifier can be tested using the diode test (or even just a continuity test) on a multimeter, the current should only flow one way, if it flows both ways its shagged, not sure how you can test it if it is combined with the regulator though if you cannot service your battery then chances are its cooked by now
November 13, 201213 yr Author Thanks mate ill check it tomoz and post back. Thanks again for all your help
November 14, 201213 yr may be worth a LOOK if you replace the regulator and it solves your problems happy days, as a crude test with the bike running keep your hand over the regulator and it should heat up, this is how it reduces the voltage by turning the excess into heat which dissipates through the heatsink, the rectifier is essentially a diode which turns the AC voltage from your alternator into the DC voltage required to charge your battery and by the look of that one in the link you should be able to do a continuity test with your multimeter leads on each of the pins,
November 14, 201213 yr Author Lol I've looked at my reg rec and mines a silver block not like the one on in the link. But yeah goin over it thouroughly today to see what i can find. Ill post back later in the day to let you all know what and if i find anything. Thanks again
November 14, 201213 yr Author To obe honest im not even sure if mine is a reg rec ive just took my mates word for it could jus be a regulator and i might not even have a recitfier or vice versa. Something else to check i suppose lol
