Yamaha Dt 50 Mx Cdi Coil
Hi everyone
I have just recently bought this bike with an intention to get it back up and running :) It was a complete basket case when I bought it and some of the parts are still missing , However I know for sure the ht coil is completely shot , As my bike is of the cdi type can I use any 6 VOLT Ac coil or must it be the specific type ???? If so any ideas where I could source one ?
Thanks for reading :)
Stu
Hi Stu, welcome to the forum!, please take a few moments to post a welcome note in the newbie section just so we can get to know you a little better.
Congrats on buying a DT, i recently bought one as a restoration project, then i bought another one to strip for parts, if you have a haynes manual and a multimeter you should be able to test the resistance of your coil, as for sourcing one, yambits is good, as is ebay, alternatively i think i have a couple of spares kicking around
Hi thanks for the help mate , I am quite new to this computer stuff and that :( , Yes I have measured the resistance ,:) The actual internal pin that screws into the ht lead as just corroded away , I can not seem a way to open it as it is sealed as you probably no , I will try Yambits again as I have had a few things off them :) Does it have to be a specific type or any type ?
Cheers mate
Stu
not 100% sure but i cant see why you cant use any 6v coil aslong as the resistance ratings are the same as the DTs'
Cheers :)
I will have a look around , on ebay and Yambits has you suggested :)
Stu
  • 4 weeks later...
We have The correct type CDi coil for your bike in stock
BTW cdi works at 200 volts, don't test it with your tongue :spin2:
http://www.rexs-speedshop.com/epages/es143131.sf/en_GB/?ObjectPath=/Shops/es143131/Products/HTC8
