This post is 4399 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi All
Just going through registration of my old RD250DX in Dubai, just air freighted out from UK.
Hoping to get a little less smokey before I have to register at RTA. Not many old two strokes seen aroundfout here.
Any tips on getting the mix right to get less of a smokey trail?
Cheers.
they all smoke and smoke a lot more until the engine is warmed up
The pump will deliver a metered quantity, this isnt really adjustable...is it an issue there then?
:greetings and :welcome:
Welcome aboard :welcome: you could go pre mix with a full synthetic oil some can be mixed out to 100:1 also shimming the pump to stroke less will make it smoke less.
Welcome Can77" give her a good thrashing b4 you go for test, :spin2: and DT50 is right about fully synthetics ,, i kno trial bikes at 80/1 ratio....
Welcome to the YOC! :)
