Help needed with 1975 DT175
Hi all,
Am new to this forum and looking forward to contibuting.
I'm currently restoring a 1975 DT175 imported from the USA, I've just bought an ignition barrel that should have fitted but the mounting points on my top yoke are too far apart. Is there 2 different versions of the ignition barrel?
Hi
Are you trying to fit the ignition switch to the meter bracket with or without the ignition damper rubber?
Aj
Hi Nayruf,
Sorry for the slow reply, somehow my time seems to get eaten up by the wife & child.
I'm trying to fit it with the damper attached as this seems to be the way the manual shows it, it was just a trial fit as I've still got a lot of work to do on it before it's back on permanently.
Thanks for your assistance.
Now sorted, had the damper the wrong way round.....derrrrrr
