Posted November 6, 201213 yr I have decided to clean up the alloy lower front forks. I usually get them polished to look pretty. This time I am going to have a crack at linishing and then hit them with non-yellowing clear lacquer. Here they are now ~ RegardZ.
November 6, 201213 yr Moderator I'd just wet and dry them, mop polish and use an alloy polish to finish (I prefer Peeks) mine have been great for 6 years and still look good
November 8, 201212 yr Author Drewpy, thanks for your comment. I usually have the fork bottoms polished, however, I thought I would try and see if I can get that original finish. This first photo is the lower front fork of a Kawaski Z1,,, Polished. The seond photo is of the Yamaha Zeal .... Linished finish (stage one). This was done very carefully on a bench-grinder linishing attachment using that pot scourer type belt. I still have to "hand finish" by standing upright in a soft jaw vice and with a long piece of "3M" pot scourer work backward and forwards to get the desired finish. I was surprised how good the "scourer" belt performed.... No groove or ripples. Stage two will tell me how well I've done, then (stage three), the POR "Glisten"... the non-yellowing clear coat. Just in case some of you haven't seen the grinder attachment mentioned above, this is it! RegardZ.
