November 5, 201213 yr Pal of mine has a 09 TDR 125 nice bike had a few owners worked fine..till last week... Then suddenly....won't go past 40.mph? I'm wondering if that Cat ( I think it has one in the exhaust has collapsed ?) If it was an early machine i'd just say it needed a decoke? it's done 9k and not been that well looked after. he's bringing over at the weekend and I'm supposed to be an appropriate expert...hah! Any help on where first to look much appreciated Apparently, it starts easily makes no nasty noises and runs well up to 40 mph...wont rev out in any gear. Many thanks bonnietiler
November 5, 201213 yr Well besides the basics plug, air filter ,compression test ,might be the power valve stuck closed.
November 5, 201213 yr Yip " as dt50 says, ditch the filtre, then the plug, see if the powervalve works, then exhaust, the last stroker i had with poor compression, was a pig to start,, but your tdr is starting good , so i dont think is comp.
