The front brake light switch on my bike has packed in now for the third time. Could there be a reason that is causing this to happen? I bought the replacements from eBay and they do seem a bit flimsy, but what else are they going to make them out of, apart from plastic? I'm sick of changing them now, but obviously it's my brake light so I can't not replace it.
Surely it can't be normal to for it to keep breaking.
Microswitch, exposed position, British summer - bad combination. Ditch the crap prone piece of sh*t and spend a few quid on banjo switches (fleabay search for "brake light banjo"), can get 'em for £10-15. They're sealed unit pressure switches made (usually) of stainless steel so they're true 'fit and forget' items, once you've gone down that path you'll wonder why you ever bothered with the normal ones.
When I did a search on eBay, the only ones that come up were the plastic ones. I'll have a look into it. Cheers.
Brake light banjo search on ebay - gotta be one there that fits ....
What breaks? Is it the metal contact bits?
I spray WD40 in there and clean the crud out every so often. Works well enough and keeps them clean/free from corrosion buildup.
I know your pain i have the same thing with the rear light switch on my DT. Its a plastic insert on a metal pin and it slips. Cheap shit, i fix it for the mot and it lasts long enough for the ticket.
One of those banjo's is the way foreward or buy a gen one.
