This post is 4449 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I have just pulled the upper & lower triple trees off a 1998 Zeal and found the 19 ball bearing surfaces galled and coroded. Do they make Taper roller bearings for this model Zeal?
RegardZ.
try and find out what the bike is based on. Yamaha usually use parts to interconnect with each other from the same time period.
bearing factors are your friends :D
Ya, I found some parts for it on wemoto (http://www.wemoto.com/bikes/yamaha/fzx_250_zeal_b_d/91-99/), but no steering head bearings... no bearings at all actually. :(
Zeal isnt sold here in the UK, what you need to find is the inside and outside diameters of the two bearings then start asking sellers to check theirs, I imagine the bearings from many bikes will share the same dimensions
Thanks guys, as Drewpy and Airhead mentioned, I was able to order a set of tapered roller bearings for the Zeal. Evidently, they are used on other Yamaha models ... XS500 and TRX something!
I will post the make and part number when they come in along with their "like" machine/s.
RegardZ.
Here is the Taper Roller Bearing Set supplied....
"LInk" ... made in Japan
Part # 90 - 140 - 03 Steering Bearing Set.
Suitable for...
Yamaha: FZ400R '92-93, TX500 '73-74,
XS500 '75-78, XS500R, XZ550, FZ600 '86-88,
SRX600, TX650 '74, XJ650/S , XS650/S
TX750 '73, XJ750, XS1, XV750SE, XV920
XV1000 '81-82.
A bit of a worry, they don't mention the little Yamaha FZX250 Zeal!
Regardz
