Hi Anthony, I have the same bike and I think that the 600 exhaust is slightly different in the down pipes, if you check the numbers on the original pipes (at the end that goes into the 4 way connector) you will see that the numbers are different and that the pipes on the 600 are slightly shorter than the original, so you might be able to use the 600 tail pipe and leave the original down pipes on. Hope that helps. :jossun:
hi, thanks for that, the bike i have has no exhaust at all so i was going to risk buying a xj600 motad 4-1, but if its pipes are shorter then you have saved me a big headache, thanks again
