Grouch Posted October 24, 2012 Posted October 24, 2012 After changing the oil in my XT 125 X 4T yesterday the gears have become very stiff and hard to change. It is almost impossible to find neutral unless I turn the engine off. Before I changed the oil the gears were smooth and were no problem at all.
Grouch Posted October 24, 2012 Author Posted October 24, 2012 The oil was Castrol Power 1 Racing 4T 10W30, the exact type specified in the owners manual. It is really pissing me off. I expected an improvement after replacing the oil, not a hinderence. Maybe it will correct itself after a few more miles.
blackhat250 Posted October 24, 2012 Posted October 24, 2012 I had this problem, and it was castrol classic W50 i used, quiet smooth box, but changes were slow[ return spring] and stuck between gears some times changed to light gear oil , and solved,
Grouch Posted October 24, 2012 Author Posted October 24, 2012 What would be a thinner top quality oil?
welshwan Posted October 24, 2012 Posted October 24, 2012 Hey Grouch! hahaha it would seam i changed the oil on the same bike and same day as you. maybe even same oil. was it that red colored Castrol oil in a gold pot? maybe there all like that idk but i have noticed your having trouble with stiff gear change after you changed your oil, just thought that i would let you know that it did NOT have this effect on my bike, all in all seams abit smoother but also more noise? haven't a clue whats going on there..... best of luck matey
Grouch Posted October 24, 2012 Author Posted October 24, 2012 Cheers, it might be the clutch going or something.
Moderator Airhead Posted October 24, 2012 Moderator Posted October 24, 2012 It should get better with a bit of use Grouch, check you havent put too much in though. Perhaps you will get netral better while you are coming to a stop but not yet stopped it's always easier like that IMO theres never any value at all in going to 1st before stopping either on 2 wheels or 4. It's also possible because you use your bike a lot that you have by now a little clutch plate wear and so adjusting the clutch at the clutch may help
Grouch Posted October 24, 2012 Author Posted October 24, 2012 Cheers Airhead, I never knock down to 1st before stopping, I just pull the clutch in lol. My plan is to leave it a few days and see if it improves, if not I will play about with the clutch. If I can find no solution I will be straight on here winging at you all lol.
Moderator Airhead Posted October 24, 2012 Moderator Posted October 24, 2012 Point is though, It's easier to select neutral from 2nd with the bike in motion
Grouch Posted October 24, 2012 Author Posted October 24, 2012 I am a bit rough with the old gears, I am really aggressive with them and just pull the clutch in and knock them down right fast while I am stopping. Do you think this may have caused the problem?
welshwan Posted October 24, 2012 Posted October 24, 2012 I'm a bit of a gear stomper myself...... my excuse is that i'm trying to get down a few gears quickly to 'back it in' the corner. that's my story and i am sticking to it
Moderator Airhead Posted October 24, 2012 Moderator Posted October 24, 2012 I am a bit rough with the old gears, I am really aggressive with them and just pull the clutch in and knock them down right fast while I am stopping. Do you think this may have caused the problem? you only need gentle pressure to go from 2 to N, like I said before , personally I think the new oil and a clutch that may benefit from adjusting are the problem
Grouch Posted October 24, 2012 Author Posted October 24, 2012 I'll have a mess about with the clutch then (once I have consulted my Haynes). When I wear my boots, I'm even more heavy handed with the gears.
Moderator Airhead Posted October 24, 2012 Moderator Posted October 24, 2012 how can you be heavy handed with boots?
Grouch Posted October 25, 2012 Author Posted October 25, 2012 Been 'heavy handed' means being very rough and hard where I am from (West Yorks) regardless of what body part you use. Its just a common working class saying.
Grouch Posted October 25, 2012 Author Posted October 25, 2012 It has improved a lot now. I'm still going to investigate the clutch though.
