October 28, 201213 yr Moderator you cant normally zero out the leads on a digital meter DT and I have never seen them read more that about 2 Ohms myself
October 29, 201213 yr Even if you can't zero the multimeter your working with you can subtract the value of the leads from the final reading,my dvom self zeros ,but my last set of leads read 35 ohms resistance before I replaced them.Mind I use my meter everyday alot. I have seen alot of good parts changed because of faulty readings,people not accounting for temp varraition. most readings should be performed at 20c and a varriance of 10 % is normal between 2 identical parts.So 660 is not that far from 700 ..40ohms -10 ohms for leads and your at 670 temp vary and that could easly be another 10 ohms 680 add the 10% and your at 700 give or take. I would be inclined to teast it at the farthest point IE the voltage reg,computer,coil and see if the wireing is to be at fault.Aswell I would check the coil.Most stator problems cause hard starting problems long before they start giving high rmp problems,just by the nature of the beast the faster it spins the more out put it has.So generaly speaking if it's a low rpm problem stator,,high rpm problem bad ign coil. Iam not saying the stator is goodjust that I would inspect everything else firstHT cap Ign coil and related wireing befor condeming a stator that is very close to the book value.
December 8, 201212 yr Author Got the bike revving, Thanks All! And the culprit was................................. .................Cdi coil! Fitted a new one and the bike revs happily now. Really got some enthusiasm now to carry on and finish the project
December 8, 201212 yr it is defo a kick in the knackers when something crops up and all you want to do it get on with the rebuild project i got stuck for months with my old 1992 nsr i ended up selling it becuase i lost the drive and passion... keep the faith and get stuck in, you will be happy at the end of it knowing it was you who got her running again!! get some pics up people like to see what there helping you with. good luck ken
December 8, 201212 yr Author Yes I will get some pics up, good idea. Like I said earlier thanks for all the help, it's been a whole learning curve but in a short I almost feel I know the bike inside out. I have decided to keep the bike for myself after all the work I've put in, I'm going to be the fastest 50cc kid in the town aged 40
December 8, 201212 yr Moderator Yes I will get some pics up, good idea. Like I said earlier thanks for all the help, it's been a whole learning curve but in a short I almost feel I know the bike inside out. I have decided to keep the bike for myself after all the work I've put in, I'm going to be the fastest 50cc kid in the town aged 40
