Aerox 50cc
shawn1982
This post is 4268 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi all,my bike started running not to well so took off the carb and cleaned was running well but not once it start and I rev it the bikes wants to cut out could this be due to the air fuel mixture not bein right on the carb or is there other bits to check cheers
Link to comment
Share on other sites
How's your air filter? Or the spark plug? I would check these before even thinking about pulling or fiddling with the carb - start with the simple stuff then work up from there. Also check the vent hole in the fuel cap is clear, if it's a bit blocked it can starve the carb of fuel.
Link to comment
Hi there thanks a lot for advise,will check 2moz some 1 else said may be spark plug so fingers crossed,I fitted a new carb it's running better not cutting out when accelerating just only reaching 15mph & bk firing any ideas cheers
Link to comment
