Clutch slip
I keep getting clutch slip on my Thunderace, I changed the friction plates and fitted stronger heavy duty springs. I done a complete oil change with filter and replaced the clutch hydraulic fluid, it seems to do it more twos up and when the oil is hot. Even drained the oil and changed oil brand
  • 4 months later...
I had the same problem, did the same, as in changing the clutch plates etc. Only really got rid of the problem when I reverted back to semi-synthetic old rather than fully synthetic
Hope this helps.
