October 12, 201213 yr On the way to work this morning, I heard a grating noise from the front wheel area that got louder during the 30 miles. Had a visual check but could not find anything. Spun the front wheel over but didnt feel like bearings. On the way home the noise got even louder to I pulled over and again could not find anything wrong. I jumped back on to move to a petrol station and then realised the noise went and now the speedo does not move. I havent had time to take it apart but I assume its the cable ??? Are these a common issue on the divvy? Can it have damaged anything else? Thanks for any replies
October 12, 201213 yr Moderator sounds like the cable seized and was winding up in the casing and then snapped! they do need oiling from time to time
October 19, 201213 yr had that happen on my pre-div, good indication is to disconnect the cable assembly at one end and gently pull the inner spring out, if it comes out then its snapped, easy to find a replacement and easy to fit
