Does anyone have a manual for the DT175E? I would just like to know the factory carb settings particularly the main jet size, clip position, and air screw position. Also if your manual specifies I am at 5000' above sea level.
-Dave
Hi
at the end of some of the pdf's for some of the bikes are basic setting data sheets, there are some high altitude settings shown also
they might be of some help,
Edited by Cynic
Sorry mate can't have links like that, orders from Alex.
Carb specs dt175 E,
main 140
needle 4j13 3rd groove from top
needle jet 0-2
pilot jet 22.5
pilot air screw 1and1/4 turns out
starter jet 20
float height 21
idle speed 13-1400rpm
As your the wrong side of the atlantic you may have a preset pilot jet screw.
Not sure as to the effects of altitude on the DT's carberation. In my part of the world the only way i'll reach 5000' is in a plane.
You guys are the best! Like I thought the 140 is a little big for my elevation.
Thanks again
-Dave
