September 29, 201213 yr well, thought I had it all sorted, set of early for mot this mornin but on the way my f left indicator stopped working, turned out to be a bad earth, but buy the time I had sorted it and got to the garage there wasn't time to mot it as they finish at 1 on sat. to make matters worse on the way home my clutch went light and then stopped working, there seems to be very little resistance there, I wound all the adjusters as far out as they would go just in case but it made no difference. any pointers of where to start greatly appreciated on the plus side I did get to ride the bike for the first time in about 4 years and its loads lighter to push on the walk of shame than the suzuki.
September 29, 201213 yr Moderator if it werent for bad luck youd have none at all put some slac into the cable, push the operating arm on the engine mounted operating lever forwards untill you feel resistance check the pointer at the end of the operating lever...against the pip on the casing adjust the clutch pressure plate adjuster to align these two adjust cable for around 5mm free play end of clutch lever
September 29, 201213 yr Author Hi, thanks for the swift reply I un hooked the cable and pushed the lever on the engine all the way forwards but the only resistance seems to be the spring
September 29, 201213 yr Moderator theres something awry then, drain the oil and look at your clutch...have the screws through the springs come undone?
September 29, 201213 yr Author If I get the chance ill pull it to bits tomorrow, hopefully itll be obvious, cheers
September 30, 201213 yr Author well, I took off the cover and it turned out that the lock nut on the end of the push rod was loose, (1980s DT 125 bottom end), following the instructions in my Haynes manual I adjusted it to the pip on the case but when the lever is pulled in it has no affect, though I can see the pressure plate moving out it wont disengage by continuously adjusting everything as far as it will go I can get to the point where it allows the bike to be pushed though there is a little resistance but at this point the lever dose nothing it still moves the operating arm and there is pressure there but its already as disengaged as it will go and when the lever is released its exactly the same, Am I missing something obvious. I still have the right hand case off so there is no oil in there but I dont think this would cause it. could the lock nut becoming lose have caused some damage elsewhere?
September 30, 201213 yr Did you turn in the screw till it bottomed out then out 1/8 of a turn before tighting the lock nut with the cable as loose as possible? Order of adjustment. 1 loosen or remove cable 2 adjust free play at basket ( locknut and screw 3 install cable and adjust
September 30, 201213 yr Moderator If I'm right on the 125 there is no adjusment in the centre of the pressure plate and the adjusment is done on the other side of the engine behind the sprocket cover... am I right?
September 30, 201213 yr Author I turned the screw untill the arm was in line with the pip on the casing - about as far as it would go ( cable off ) The adjuster is in the centre of the pressure plate.
September 30, 201213 yr If the arm has been installed in the wrong position then it will never line up with the case,, just take the free play out fo the push rod then worry about lining everything up.
October 7, 201213 yr Author Put it together and adjusted it as far as I could, got a small amount of free play at lever but the clutch still drags slightly, wondering if I should try a different grade oil ive put 10/40 in, good news is it passed its mot on Saturday :hyper: :hyper: :hyper: :hyper: :hyper: Massive thanks to you all for your help, especially Airhead seems like its been a long road and its not over yet still a few niggles to sort but at least I can ride it now, Had to mot both my bikes on Saturday and the Dt was the star of the show. I lent it up against the wall at the garage (no stand) and went in to pay, when I returned to it there were two blokes stood admiring it, I was greeted by "where did you find this little treasure mate" , looking forward to showing the guys at work tomorrow just got to gently run it in over the next couple of weeks. thanks again all
October 7, 201213 yr Moderator Great stuff Sam It's been a bit of a journry for you eh...It's always nice to see one of the DT's returned to the road...Hats off to ya and dont forget to post up a piccie eh? keep in touch Oh yeah...if the clutch is dragging a bit and you havent over filled the oil and if it doesnt get better after youve run the motor in why not try some thinner oil http://www.opieoils.co.uk/p-934-motul-transoil-10w-30-lubricant-for-gearboxes-with-wet-clutch.aspx
October 13, 201213 yr Author Stripped down the clutch today and cleaned all the plates with a bit of petrol, I noticed there was a little surface corrosion on the plates so I polished them up with some very fine wet n dry and a little auto sol . Success, nice light clutch working properly Ive done about 100 miles on it gently so gave it a little stick today, feels like its boging down a little so think ill try a smaller jet its got a 160 in at the moment any ideas where I can get a 150 from i cant find it on yambits or wemoto, thanks
October 13, 201213 yr Sam" search Mikuni jets on ebay, thers lots,,, & more bogging down issues, thers a thead here someplace,, airbox . etc
October 13, 201213 yr Moderator Stripped down the clutch today and cleaned all the plates with a bit of petrol, I noticed there was a little surface corrosion on the plates so I polished them up with some very fine wet n dry and a little auto sol . Success, nice light clutch working properly Ive done about 100 miles on it gently so gave it a little stick today, feels like its boging down a little so think ill try a smaller jet its got a 160 in at the moment any ideas where I can get a 150 from i cant find it on yambits or wemoto, thanks Sam buy your jets from allens, they are genuine ones not pattern...so you can trust what it says on the jet, might be worth buying a few different sizes they increment in 5's at this size http://www.allensperformance.co.uk/
October 13, 201213 yr Author Thanks both, ill give allens a call on monday and yes at the price i should likely try a few sizes, Im assuming that by sealing up the air box propperly i have reduced the air flow, I have not oiled the air filter yet, its dry but once I do there is no going back
October 13, 201213 yr Moderator yeah if you oil the filter it will run even richer but it should be oiled anyhow
