2006 ybr 125 06 no spark
hi i have a ybr125 06.someone tried to nick it
stole the ignition barrel
i replaced the barrel,soldered the wires together
replaced the main 15 fuse bike light turn on but there is no spark,i replaced the spark plug no spark
im thinking it the coil
can any1 help
cheers
Haynes manual; No Spark or Weak Spark.
Battery voltage low
Spark plug cap or lead faulty
Spark plug cap not making good contact
ECU defective
Crankshaft position sensor defective
Ignition coil defective
Ignition switch shorted
Wiring shorted or broken
cheers for the reply
but i have seen a alot of people having trouble after they change the ignition barrel
has anyone solved this problem if so how
Does the engine turn over?
What kind of spark plug was in the bike, Iridium or Platinum ones can give a good spark to a lean fuel mix.
For the sake of a few quid, you might as well get a replacement coil and it's not at fault you can always sell it on after. > http://www.ebay.co.uk/itm/Yamaha-YBR-125-Ignition-Coil-and-HT-lead-for-2006-CARB-models-/290778933054?pt=UK_Motorcycle_Parts&hash=item43b3c6673e
And some other wiring bits > http://www.ebay.co.uk/itm/290778939084?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Call out charges and workshop fees are a bit of a rip, but you'll spend days trailing through Haynes manuals, wiring and various wiring diagrams going nowhere otherwise.
