Posted September 12, 201213 yr hi i have a ybr125 06.someone tried to nick it stole the ignition barrel i replaced the barrel,soldered the wires together replaced the main 15 fuse bike light turn on but there is no spark,i replaced the spark plug no spark im thinking it the coil can any1 help cheers
September 12, 201213 yr Haynes manual; No Spark or Weak Spark. Battery voltage low Spark plug cap or lead faulty Spark plug cap not making good contact ECU defective Crankshaft position sensor defective Ignition coil defective Ignition switch shorted Wiring shorted or broken
September 17, 201213 yr Author cheers for the reply but i have seen a alot of people having trouble after they change the ignition barrel has anyone solved this problem if so how
September 20, 201212 yr Does the engine turn over? What kind of spark plug was in the bike, Iridium or Platinum ones can give a good spark to a lean fuel mix.
September 23, 201212 yr For the sake of a few quid, you might as well get a replacement coil and it's not at fault you can always sell it on after. > http://www.ebay.co.uk/itm/Yamaha-YBR-125-Ignition-Coil-and-HT-lead-for-2006-CARB-models-/290778933054?pt=UK_Motorcycle_Parts&hash=item43b3c6673e And some other wiring bits > http://www.ebay.co.uk/itm/290778939084?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 Call out charges and workshop fees are a bit of a rip, but you'll spend days trailing through Haynes manuals, wiring and various wiring diagrams going nowhere otherwise.
