Is there any way that i could find out which units will be suitable for my bike.
The one that is in is labelled TID14-39
IAE-10 With 602 stamped in the silver box
Having said that, which gasket sets could i use for the same engine? It is sooting up all four plugs after maybe 100 miles. I have noticed that the inlet valve on cylinder one could do with a regrind so i am assuming all eight will need doing, therefore a gasket set is need before i start.
Its an XJ750RL imported and about a 1983 manufacture
Aye litte,j" check out speedshop, www, hes a member on here, they doe remakes of CDI, for lots of models,,,
sooting up plugs, shes running ritch,,, check float levels, and air filtre.
I was wandering if it was the carbs causing my problems, but would all four go the same?
Also, i get no flooding when idling or with the engine off. I do think that a carb overhaul woould be useful but this will leave me with the conundrum of which gasket sets/jets should i get. Would i be wise to get the same as our 750 SECA?
