Yamaha Virago starting issue
Hello, i was taking the bike for a blow out when she stopped all of a sudden. its like when i try to start her there is a whirring noise. i checked the starter motor and its fine. its like there is a cog that isnt connecting to crank the bike up.
she had a new stator fitted and i checked the voltage and was constant.
Any advice would be much appreciated
  • 1 month later...
I have similar symptoms on the the non starting bike I have just bought from a mate. It is being delivered on Tuesday and until I get the cover off to diagnose the fault I just don't know, could be the clutch, clutch rollers and springs or the idler and starter gear not meshing correctly. The bike turns over a couple of time and then clunk as the compression builds up. If the plugs are removed it turns over fine.
http://www.youtube.com/watch?v=qsmCj5fwMvM&feature=relmfu
try this if you have the 535, other models have a starter bendix
