front brake bleeding
hi all
could someone help with problem i'm having bleeding front brakes on T-CAT
can not get ant movement on both front calipers even after bleeding the system
yes i have had to dis connect banjo bolts to release caliper retaining bolts hence all fluid drained out
Fluid is pumping through when you bleed?
Might pay to take caliper pistons right out and clean and then rub "smear" of red rubber grease round piston seals and pistons to ensure slidability of them.
